StephenJames
I think the last pair I did with sonions were around 18-19mm, as things get a bit tight around the aperture (I think that's what it's called) part of the shell.I would not listen to anyone who recommends option 1.
Do not use anything smaller than 2mm ID for TWFK otherwise you will kill all usable high frequencies and with 1mm ID you'll move first peak to honky 1,5kHz it will sound like a low quality radio.
For CI use any of the above options, but TWFK 2mm ID is necessary unless you are going for something like a horn with combination of 1mm or 1.5mm and 2mm.
You didn't specify lengths of tubing you plan to use. My recommendation would be anything between 12 and 18mm.
I haven't tried the GK's in the custom shell yet, just a generic universal shape to test things out.
