I've rebooted everything countless times last night as well as this afternoon, and always shut down before doing any cable swapping as a safe practice. When the mR or any AoIP in the chain the Mac "MIDI" settings and JRiver "Audio" settings cannot be accessed, so I don't believe it has anything to do with the Mac, rather it is just easer to blame. Don't forget, there are no drivers to install for the Mac to use with the SU-1. I'm waiting to hear from Tim at this point being I've spent a good 6hrs now trying to figure this out to the best of my ability.Joseph, I was also having some Problems at first with Static and not getting anything to pass through the SU-1 But after several attempts at rebooting everything and taking everything in and out of the chain, everything started to work, I'm also on a Mac, Tim says most of his issues are with mac issues.
I do know with your MicroRendu, you should be able to pass the signal, I myself am using Audirvana Plus newest version...
Tim wrote this to me below about my situation.
Also i2s cables are not hot swappable, so hopefully you did not plug or unplug them when either device is powered on.
Try a power reset of all devices. And plug and unplug the input side of the intona also. Mac's often are picky with USB sometimes. Most of the tech support I do ends up being about 80% Mac and I wish I had a Mac so it could be a little easier. I'm not too familiar with Mac. And the only way Mac can do dsd is with DOP. And limited to dsd256 over DOP. Never can do native unless they update the os.
As I mentioned above, I highly doubt it's my Mac because there is no access to any settings using AoIP so I hope it's not an issue with the DAC or the SU-1.This suggests to me the issue lies with the dac or your computer. Have you try uninstall and reinstall the driver?
Thank you both very much for your replies, I do greatly appreciate them!
