EDIT: Holo/Kitsune resolved the situation, so post deleted.
Some interesting wording in thereAnd the usb module we are talking about is NEW and far better than the one you are familiar with.
t. We have run out of enhanced usb modules and they have been superseded by the new usb module processing we created to replace it. Far better performing module with better support for high resolution content. Dsd1024 and pcm1.536mhz is achievable on most any platform now, as before it was only available with intel chipsets and some other chipsets but amd and many other chipsets had issues where dsd512 was maximum possible. Or pcm 768k.
The new usb module is more of a perfect match for the dac too. Better measurements and improved sound quality. And no extra charge this this module. However we are to be delaying orders getting the upgrade as we are a small waiting for pie shipment of the completed boards. Should be about a week.It’s superseding the original enhanced usb module found in kte may, L2 May and kte spring3
and the site has no updates about a new USB
they’re essentially not even advertising this upgraded usb
Pretty awful on their part
Fair point D9It is not just about sound quality - The DAC sounds fantastic. This issue of concern is the compatibility with AMD and being able to get beyond 768 and DSD 512. This is not fixed in any firmware if you are on AMD. Therefore, a new module that supports both Intel and AMD is much desired for myself, at least. Considering one reason I bought this DAC was to explore up sampling and DSD at higher rates.
"better support for high resolution content. Dsd1024 and pcm1.536mhz is achievable on most any platform now, as before it was only available with intel chipsets and some other chipsets but amd and many other chipsets had issues where dsd512 was maximum possible. Or pcm 768k"
I am bound by the limits above in bold ATM, so the statement in quotes, does have an impact.
I really doubt that the new module it'll make any difference that's audible anyways the current one is already beyond the threshold of human hearing I think Tim was just up telling me to keep me calm with how long my order was taking
You may be right, but personally I am guessing the other way. If you are right, then that means Tim's comments about the new usb module are just pure marketing fluff (reposting Tim's email below with some points of emphasis). I'll give Tim the benefit of doubt and assume what he wrote in his email to you is true and the new usb module will have noticeable sonic improvements and not just better measurements.
DAC manufacturers have been telling us for years USB issues have been solved, but that is not the case. Those of us that have bought, tried, sold numerous usb DAC's over the years can attest to that. Schiit, Holo and many other DAC manufacturers are constantly trying to improve USB.
The fact that Holo has implemented a new usb solution to replace Titanis 2.0 tells you that Holo themselves didn't think Titanis 2.0 was so good that further sonic improvements could not be obtained. And, whatever they call this new usb module, rest assured it too will be further refined in a new version in a few years, which is fine. Just don't release a product knowing that you will be upgrading it immediately, leaving early buyers behind.
With respect to the new usb module, I'd find it pretty much impossible to believe Holo did all of the R&D, parts sourcing and parts ordering all after the first units shipped. Be transparent, tell your customers what is happening and allow them to make a choice between getting the DAC sooner with the soon to be replaced usb module, or wait for the new one.
Instead, we get... Place your preorders now. Once the pool of preorders have been filled, just sit back and cross your fingers. You will all pay the same price but, some of you will get the better version, others won't be so lucky, but just roll the dice and play!
"We have run out of enhanced usb modules and they have been superseded by the new usb module processing we created to replace it. Far better performing module with better support for high resolution content. Dsd1024 and pcm1.536mhz is achievable on most any platform now, as before it was only available with intel chipsets and some other chipsets but amd and many other chipsets had issues where dsd512 was maximum possible. Or pcm 768k.
The new usb module is more of a perfect match for the dac too. Better measurements and improved sound quality. And no extra charge this this module. However we are to be delaying orders getting the upgrade as we are a small waiting for pie shipment of the completed boards. Should be about a week.It’s superseding the original enhanced usb module found in kte may, L2 May and kte spring3."
Sounds like a used car salesmanYou may be right, but personally I am guessing the other way. If you are right, then that means Tim's comments about the new usb module are just pure marketing fluff (reposting Tim's email below with some points of emphasis). I'll give Tim the benefit of doubt and assume what he wrote in his email to you is true and the new usb module will have noticeable sonic improvements and not just better measurements.
The fact that Holo has implemented a new usb solution to replace Titanis 2.0 tells you that Holo themselves didn't think Titanis 2.0 was so good that further sonic improvements could not be obtained. And, whatever they call this new usb module, rest assured it too will be further improved in a new version in a few years, which is fine. Just don't release a product knowing that you will be upgrading it immediately, leaving early buyers behind.
With respect to the new usb module, I'd find it pretty much impossible to believe Holo did all of the R&D, parts sourcing and parts ordering all after the first units shipped (i.e. less than 30 days to accomplish all this). Be transparent, tell your customers what is happening and allow them to make a choice between getting the DAC more quickly with the soon to be replaced usb module, or, wait for the new one.
Instead, we get... Place your preorders now. Once the pool of preorders have been filled, just sit back and cross your fingers. You will all pay the same price but some of you will get the better version, while others won't be so lucky, but just roll the dice and play!
If you're meaning me then the delayed review is unfortunately just cause RL has gotten in the way a fair bit the last few weeks. Vaccine knocked me out for a few days, heatwave made filming basically impossible, and have had to spend time on actual work stuff (the reviews are not my job, in fact I make 0 personal income from them, it's just my hobby so unfortunately that does mean that I can't pump out videos as fast as some others).Yes, I think its odd too that there are not more folks reporting in with good or bad impressions. Also, there was at least one popular reviewer who had a unit in before launch and was going to drop a review soon after - nothing but crickets from there too, it's weird.
I know I'm being slow to get some more in-depth impressions posted but, I replaced several components in the source chain pretty much back-to-back, and now have too many "new" things to sort out before being able to present thoughts other than the highly subjective with no detail - "Best DAC I have owned so far"...
Spoiler: I do think it's the best DAC I have owned so far but it is not the perfect DAC nor my last, but it is here to stay for a while and has top positioning in my primary setup.
Glad you're up on your feet. I look forward to to your tear down n review. Do you plan a vs may section. I figure you're getting 70 percent of May 1?If you're meaning me then the delayed review is unfortunately just cause RL has gotten in the way a fair bit the last few weeks. Vaccine knocked me out for a few days, heatwave made filming basically impossible, and have had to spend time on actual work stuff (the reviews are not my job, in fact I make 0 personal income from them, it's just my hobby so unfortunately that does mean that I can't pump out videos as fast as some others)
Though the review will be up as soon as possible, and will be very positive. It's a truly spectacular product.
In terms of the USB module stuff, this unit has the same module as my may, I've not tried the new one, though from what I understand it's not really meant to be a SQ upgrade, it's just meant to get around the 1.536mhz on AMD limitation. So if you have an intel PC then it won't really bring you any benefit anyway.
Personally I use a small fanless intel mini-PC that I got on amazon for ~£150 as my source which means 1.536mhz works flawlessly (mele mini PC with HQP OS for those wondering, and the ifi iGalvanic also can go inbetween if desired).
I understand some people's frustration at not having the newer module, but honestly, product revisions, tweaks, upgrades etc happen all the time with just about any brand. Hell Audeze released the new LCD-X revision about a week after my review went up. Aryas got a revision shortly after I bought them, the AHB2 has had some firmware tweaks to allow things like turning off the eco-shutoff which mine does not have.
When you buy a product, you're buying the product described. Just cause something changes or even if a v2 of whatever you bought comes out the next week, it doesn't suddenly make your product any different/worse than it was when you bought it.
It is not economical in any way for a manufacturer to give all owners a replacement or upgrade when a minor change is made. If this sort of service were expected, the base cost of the item would need to be vastly higher to cover the costs of doing this in advance. There is no free lunch and it needs to be paid for somehow.
This is a workaround for an issue that affects only HQPlayer users with AMD pcs. They haven't released a new dac...
(Also I'm pretty sure you can email them and purchase the upgrade if you have a current KTE. And for those saying that it should be free....that module isn't free to make. The only other option they'd have would be not to offer any new module at all which would be silly.
It'd be a bit odd to say that manufacturers shouldn't ever fix issues or make upgrades to their products)
Yeah there will be some comparisons to May.Glad you're up on your feet. I look forward to to your tear down n review. Do you plan a vs may section. I figure you're getting 70 percent of May 1?
Thanks for the little preview I really appreciate your review style it seems like you have a mix of objective and subjective and I can appreciate that sound especially in music is definitely a bit of bothYeah there will be some comparisons to May.
Basically the performance you get from spring 3 is similar to May, but there is a noticeable difference.
May is definitely the better DAC, but it's not worlds apart or anything. There are some sound signature differences though which I'll go into in the video.
If the May L2 fits in your budget, you should go for that. But at just over 2k, the spring 3 is crazy good value and leaves stuff like the qutest, ares 2, x26 pro in the dust.
It's nice cause the pricing is such that the May makes sense if you can stretch to it, but the spring 3 is amazing for the money. You really can't go wrong with either.
Oh...and having a proper integrated preamp is absolutely fantastic
Absolutely , and I discuss objective vs subjective in some length in the next videoThanks for the little preview I really appreciate your review style it seems like you have a mix of objective and subjective and I can appreciate that sound especially in music is definitely a bit of both
