well..... not yet officially released. need to waitAny technical details about it?
said it supports up to DSD1024 and PCM1536
Detail here.Cyan2 inside ( as from local agent )
There are PC tools to build new bootable sd card but otherwise works out of the box if you aren’t rebuilding a new OS boot card.
Well are you using as DDC or streamer? I think there may be a PC audio driver if using as DDC but not needed if using ethernet from PC to Holo to (for example) USB to DAC.I just thought I remembered having something like a Holo Audio Suite or something of that sort installed, but I guess not, thanks for the quick response.
Then yes, you should look to download Windows audio drivers. I run a Mac so not applicable.I was using it as a DDC when I had it plugged in previously.
Halo.Does anyone know where I can find all the original files for the Red? Just purchased one used and it's not being detected on my network, although it works over USB. Just need to figure out if I need to change some config or something, but no idea where to start as it's not being assigned an IP by my router.
Thanks![]()
