Holo Audio Red Streamer
Nov 27, 2024 at 1:23 PM Post #2,356 of 2,585
Has anyone considered dropping in the CM5 into the Red now that it's available?
Out of curiosity if the new CM5 is compatible w/ the Red, what would be the benefits of it over the current module?
Nov 27, 2024 at 1:36 PM Post #2,357 of 2,585
Poweeerrrr Raaammmm 🤟🤣
Nov 27, 2024 at 1:59 PM Post #2,358 of 2,585
Nov 27, 2024 at 2:11 PM Post #2,360 of 2,585
Ok lets try this again, what will the CM5 do for the performance of the Red that it can't already do?
Nov 27, 2024 at 3:29 PM Post #2,361 of 2,585
If you use the default RED OS, nothing, it's meaningless.
For the power users that know what's up, Gentoo Player is the operating system to use.
With Gentoo Player, you can install High Quality Player (HQP) to oversample.
HQP depending on the filter used needs lots of CPU and RAM.
CM5 replacement would open up much more filters to potentially use.
I opened up my RED today to see, and it does appear the CM4 has standard non-soldered connection to the RED PCB. CM5 does look like it could be a drop in replacement. I'll be watching this thread in hopes of somebody willing to try it!
Nov 27, 2024 at 3:49 PM Post #2,362 of 2,585
Not sure about CM5, but CM4 which comes with Red can be replaced without any soldering. When I got Red, for some silly reason Red could not be detected in network. Then magnahifi send me replacement CM4 module and ask me to replace myself, which I did.
Nov 27, 2024 at 3:54 PM Post #2,363 of 2,585
That's key information, thank you for relaying it.
Also this Youtube video claims almost complete backwards compatibility. He tested CM4 -> CM5 drop in on a handful of PCB's and only one had a slight issue.
It's really looking like 90%+ chance CM5 could be drop in for RED. I'll probably order one myself just to try, it's not that much. If it doesn't work, I'll just put the CM4 back in, no harm done.
Edit:
To be clear, the only thing I was wondering was if CM4 was somehow soldered or permanently attached to the RED PCB.
@musicinmymind confirmed the CM4 is replaceable.
CM5 has the exact same layout, connection port, and pin layout. It is a 100% fact it will fit into the RED PCB.
Now the only thing I'm wondering, (which is the 90% part) if the RED PCB components will be cross compatible with CM5.
From the Youtube video I linked, it's seems very possible all components would work just fine.
Nov 27, 2024 at 4:12 PM Post #2,364 of 2,585
I couldn't have said it better myself
Nov 27, 2024 at 4:38 PM Post #2,365 of 2,585
Some points for reference:
If you run HQP on the Red/Gentoo, you will be limited to using the Red as a DDC. To the best of my knowledge, you can't run HQP and use that same device as a NAA.
The generally recommended minimum RAM spec for HQP is 16GB...I don't believe the Red has that much.
Broadly speaking, you will need much more power than that available on the Red (regardless of CM4 or CM5) to run substantial upsampling filters. Even using an M4 Pro MacMini with 48GB of RAM, there are limits to which modulators I can run for DSD upsampling depending on the sample rate of the source material. PCM is much less intensive, so that "might" be possible on the Red, but in my experience, doubtful if you're looking for excellent performance.
Nov 27, 2024 at 4:49 PM Post #2,366 of 2,585
I'll have to look into this.
Absolutely correct, no way CM5 is ever going to run DSD oversampling, ever.
It can do PCM oversampling, poly-sinc-gauss-halfband with LNS15 at 768Khz I'm sure it could do.
Nov 27, 2024 at 4:55 PM Post #2,367 of 2,585
The only way to know would be to try, but personally, I don't think it has enough RAM.
Nov 27, 2024 at 6:22 PM Post #2,368 of 2,585
Thank you for answering my question. However, I don't see how you are going to have enough processing power out of this lil module to run HQP?
I guess perhaps if your use case doesn't use filters or modulators that require much power and are sticking w/ PCM it might be possible but I wouldn't hold my breath.
I have a 13700K + 3090 and while it handles HQP just fine I can see how much stress it puts on my system so expecting this lil Pi unit to be able to do the same seems like a pipe dream but I'd love to be proven wrong so if the shoe fits DO IT!!!
Nov 27, 2024 at 6:23 PM Post #2,369 of 2,585
yes, the only solution remains to mount a dedicated and sufficiently powerful pc. I tested several times HQplayer embedded with the Holo red and it is impossible to upsample beyond 384khz and it depends on what filters you need, so there are a lot of difficulties.
I continue to use HQplayer from my laptop.
Nov 27, 2024 at 6:27 PM Post #2,370 of 2,585
