@kingoftown1 I think Sinc-L, LNS15, 1.536Mhz is now my favorite too!@Tobes Sinc-Mx was my favorite for a long time. To my ears, it wasn't missing out on much. Comparing Sinc-Mx to Sinc-L to me seemed a bit like the copper vs silver cable stereotype.
Spacious, detailed with great realism and very solid imagery with the least amount of digital shimmer. Bass is super solid and punchy too.
The only down side is that being a very long filter it has most delay at startup/stop/track skipping - though not an issue for listening to albums or playlists without intervention.
I tried a bunch of filters after Sinc-L trying to find similar properties with less delay - but no dice.
For me its superiority is most noticeable on my speaker setup.
Edit: BTW Jussi lists Sinc-L as recommended for classical - which I don't listen to that much. I find Sinc-L excellent for Electronic, R&B, blues, Jazz, Rock, Folk - and preferable to me for these genres over other filters I've tried (so far).
These are the settings I mentioned using above. Seems to run fine on the M1 mini - but I prefer the PCM filter settings above. In isolation this filter setting sounds fine.If you have the compute power, compare it with Sinc-MX, ASDM7ECv2, DSD256. I suggest a female vocal that you're familiar with as a comparison.
