bogi
- Mar 16, 2013
I guess ir should work well for DSD256.Thanks, it is 8th gen i7.
Switch to Ultimate Performance power plan using some of the guides if you don't have it already set. It helps to keep CPU frequency high. It doesn't make your notebook loud or hot in the case of low load. I'm on such a power plan for years.
Then just try the trial, default settings are ok for start. A very basic quick start guide appears here: https://www.signalyst.com/quickstart.html
