bogi
- Mar 16, 2013
@OhmsClaw Since you mentioned Windows in PM:
If you want to run HQPlayer on Windows and if you don't want to run Roon, then stick on Qobuz instead of Tidal and you don't need anything else than HQPlayer Desktop (with HQPlayer Client, which is part of Desktop installation, the same license applies). So easy.
Then you also don't need Holo Red if your Windows computer is not loud and it can be placed near Cyan 2.
Or you can use a cheap low power Pi4 as NAA instead of expensive Red if you want to place your Windows computer distantly.
HQPlayer Client can run on your Windows HQPlayer PC. If you don't want to operate HQPlayer from HQPlayer PC, you can run HQPlayer Client on Windows tablet. Alternatively you can run it on Windows PC and use VNC or any other desktop sharing app to connect to it from any Android or iOS device.
HQPlayer Client has enabled touch interface, so it is suitable for tablets. On Desktop PC you can operate it traditionally with mouse.
