I tried the Bliss KTE and the Serene L1 on the same two-channel speaker setup using the Holo Spring 3 KTE as DAC.
Comparatively, the Bliss KTE sounds more treble-forward, with more excitement and a very open soundstage. Not harsh in any way but has a very high resolution. There could be slightly more bass and body but the treble sparkle is super. Perhaps the treble sparkle is for pairing with the Susvara, which has a gentler treble.
Serene L1 is smoother, more "analog" sounding, more laid back, less treble sparkle but more body. Gave my solid state system a little "tube"-like fluidity and roundness. There is a choice of XLR1 and XLR2 outputs with different impedances and sound different. It is very sensitive to power cable and system changes.
I wish I had a Serene L2 for comparison but others had said that L1 and L2 are very similar on speaker setups.
I never could you hear a difference between boutique interconnectors and Mogami / WBC cables. Not saying its pure snake oil, but I am yet to expirience a boutique XLR cable that does something differently.
Look around especially aliexpress for value for money cable, personally I can definitely hear difference between different cables. I build my own cable also. I also have boutique cable (like Ansuz diamond XLR) . If you can't hear or cable make no diff I would like to congrats to you cos you save a few tons. For holo stacks, I found that using quality silver cable preserve the transparency.
In my pass years of experiment, I found a really cheap but very good quality silver coated copper cable has the most performance/value.
Do you have an alibaba link to "good value" cables maybe? I definitly heard a difference between regular RCA cables when I upgraded to Mogami, but had a friend around with 1k euro silver XLR cables around and after many tries I couldnt hear a difference to mogami for some reason.
Here you go. I bought many years ago. These one you have to try for yourself.
Just found this amazing item on AliExpress. Check it out! SG$6.23 45% Off | 10m Audiocrast High Purity Silver Plated 6N OCC Wire Copper Cable For Hifi Audio DIY Amplifier Headphone Speaker cable https://a.aliexpress.com/_mMsMfR8
I recommend trying silver in the chain for Susvara owners. They can be polite sounding but the silver XLRs and silver headphone cable have awakened them in my system. Incredible transparency and warmth, which don't usually happen at the same time. I'm getting no brightness, just a natural sound that's quite pleasing.
