Snake
- Nov 20, 2003
I guess nobody bothered to [actually] read the links I provided regarding materials stress.
Because actual driver excursion is a computation of 2 factors - frequency and volume. A 140Hz wave can cause any driver to reach full excursion...if the amplification placed upon it demand it.
As I said, I guess nobody bothered to look at the links provided. Even though I am not a materials analyst the (second) link provides explanation of elastic failures. Here is another:
http://www.trueaudio.com/about_3.htm
All driver motor systems have a linear limit, the area where linearity in response starts to degrade. However, this limit is quite a bit less than absolute limit of excursion of any (and all) drivers - therefore driving any driver to a certain volume limit moves the performance outside the linear area.
http://www.meyersound.com/products/technology/qa.htm
http://www.mcsquared.com/nsca98.htm
Now plug all that into my first quoted links regarding elastic material deformation.
It should all be apparent once the ding! lightbulb of assimilation hits
Originally Posted by rodbac [edited- I see what Snake is getting at] Snake- if I understand your point correctly, you're assuming that reproducing a 140Hz wave will require 2/3 of the available excursion from both drivers (using your example). What on earth leads you to believe that? |
The myriad factors that figure into design considerations to generate 100db 140Hz in a room versus the same in a headphone make your point pretty tough to grant. |
We can see that the excursion response of this driver at its full rated power of 75 Watts goes over both the mechanical and linear excursion limits. At 50 Watts the excursion stays just under the mechanical limit but is over the linear limit at the lowest frequencies. At 25 Watts the system just hits the linear limit (Xmax) at the lowest frequencies. |
How does Meyer Sound ensure linearity in drivers and systems? (snip) |
Sensitivity, Power Handling and Output (snip) |
