There's no need for that at all, just keep things lighthearted, friendly and respect people's opinions.Let’s just mute him or something
High end (IEM) cable thread: impressions, pics, comparisons and reviews.
- Thread starter flinkenick
- Tags
- cable
mvvRAZ
I’m generally with you there but this is borderline preachingThere's no need for that at all, just keep things lighthearted, friendly and respect people's opinions.
He’s probably monitoring threads to see if anyone dares mention a cable and bam starts copy pasting his “objective” truths
Not only that, most of these blind test “studies” are based on speakers for the most part, and as pithy said, the sample sizes and selection are questionable at best - the only thing that speakers and IEMs have in common is that they both produce sound, but the technology in them is fundamentally different
Not only that, the so called studies are entirely based on short listening times, you get given one cable, music is played and your answer is awaited. Rinse and repeat for X amount of trials
A good cable doesn’t entirely change the sound, it reveals itself in subtle and specific points where you really marvel at what it is able to do
Even if it is a placebo, who the **** cares
If I had a Ferrari, I wouldn’t want to put the steering wheel of a Toyota Prius in there, I want the full experience to be 100% Ferrari
It doesn't matter and (in my opinion) it does not help to speculate on someone else's motivations. Just point out that this is not the thread for it and they are welcome to just have a casual chat about cables if they want. Friend of mine thought cables were ridiculous and he still bought really expensive ones because of the ergonomics. That's fine too. This isn't the Sound Science forum, we don't burn heretics at the stake.I’m generally with you there but this is borderline preaching
Foreal tho, ergonomics in effect audio cables is downright magical.ergonomics
mvvRAZ
That and looksForeal tho, ergonomics in effect audio cables is downright magical.
A well braided cable with shiny pretty materials and insulation is one of the most satisfying things I’ve owned
- Sep 28, 2016
Until it turns into dried spaghetti after a yearForeal tho, ergonomics in effect audio cables is downright magical.
mvvRAZ
Depends on how you use it. If you keep them away from sunlight and humidity they should be fine for however longUntil it turns into dried spaghetti after a year
The cable is generally the component that takes the most punishment out of the whole chain, you gotta look after it
Exactly. It will become stiff and microphonics effect will be huge and annoying.
- Sep 28, 2016
I buy iems and by extension cables, to be portable .I have iems in my ears all day long, indoors and outdoors. I expect cables to at least survive the year. Effect audio can't do that.Depends on how you use it. If you keep them away from sunlight and humidity they should be fine for however long
mvvRAZ
No cable without external sleeving can do that, PVC as a material has certain limitationsI buy iems and by extension cables, to be portable .I have iems in my ears all day long, indoors and outdoors. I expect cables to at least survive the year. Effect audio can't do that.
- Sep 28, 2016
And that's why regrettably, iems with fancy cables are for home use for meNo cable without external sleeving can do that, PVC as a material has certain limitations
mvvRAZ
I'm with you there brother..And that's why regrettably, iems with fancy cables are for home use for me
I generally use my Savant II when I'm outside, with a cheap cable that simply gets the job done. When I'm in the office or at home it's the fancy stuff.
I still can't delay this aside from buying more cables and swapping often.Until it turns into dried spaghetti after a year
- Sep 28, 2016
Lucky you dont like headphones xDI'm with you there brother..
