pippen99
Big +1 for Lumin. I had a U1 for almost two completely hassle-free years. Right now I am listening to my T2 while my Rossini is away for the Apex upgrade. Lumin is quality equipment.
you quoted a rather long and nuanced post about someone's audio journey and then responded "expensive does not equal best. grasp that." it appears to me that the person you're responding to is an intelligent and reasonable person who is not chasing luxury or frivolously spending money but rather has audio goals and has been trying to work towards them to the best of their knowledge. i guess. grasp that
I've been pretty committed to Shunyata cables in my system. I did find that the bottom end filled out as I went up the price ladder, really starting at the Alpha level. I really like the noise reduction effect they have, but have also found that other cables may have more color (for example the generally very overpriced but nice sounding and bass heavy Transparent Audio).
first time trying Shunyata cables. this is the Venom-X EF power cord, that comes in 1.75m standard length.
the US plug end fits snugly into my conditioners; no looseness or cord sag. the cord itself is very light and is very flexible, so very easy to route. the iec end is a slim body style and also fits snug and tight into my component sockets.
sound wise, this cord seems more forward with emphasis on the top end. it has a clear upper registry and vocals are brought up front and center. the low end is very tight and detailed but leaves me wanting for more in terms of rumble/heft.
in contrast, the Furutech dps 4.1 and AQ power cords have a fair bit more low end, but also do sound a bit bloomier and less controlled. top end is also less sharp/clear compared to the shunyata cord.
I'd not pair the shunyata with an overly neutral/detailed centric system. it does do well with my Primaluna tube pre, but I prefer my other cords with my nad m23 purifi amp. closest sound sig power cord I have to the shunyata is my WyWires platinum.
I do mostly solid state and it works well for a transparent, dynamic sound, and did use them with 23r for a time. But for some reason when I had the DCS Bartok the combo was brutally harsh.
They might not be the right fit. I have found that they often take a long time to settle in my system, but the bass doesn't change much.I was hoping the bottom end would fill out with these cords. doesn't seem like it is happening though.
I'm probably going to switch back to my Furutech and AQ cords for the pre and power components. just wish those cords weren't so heavy, thick and stiff, and difficult to route.
Anyone tested Atlas Eos Superior/EOS 4DD?
Have both in my system at the moment. Roasty pretty much nailed it for 4DD. Superior is completely different type. More open, very balanced all frequencies, timbre a bit lacking compared with best.Anyone tested Atlas Eos Superior/EOS 4DD
