$500 for a USB cable? Yeah, I have some comments, but you probably don't want to hear them.
The ones I'm using now cost a few hundred more...
Why man?... Starlight 8 is released already!
Definitely the nicest case I've seen so far for a USB cable lol! Really nice quality. Solid connectors too.
Also decided to try an aes/ebu cable to compare against i2s. Ordered a synergistic research lvl 2 atmosphere X Excite.
Should be a fun weekend!
My experience with i2s and aes/ebu is pretty much the same. I2s tends to have a sweeter high and comparatively silkier sound, so I'd describe it as energetic; Aes/ebu tends to have better low ends. although the high is not as sweet as i2s. All in all it gives a "darker" and sophisticated sound.
So there is no winner in this competition. Your preferences are the only thing that matters, LOL
On the side note, SR cable is a great choice but grounding it will make a HUGE difference. With a nicer grounding cable, it will work even better!
Oh thanks for that. The validation makes me think maybe I'm not so crazy lol! I'm just using the included grounding cable that came with the aes/ebu. What do you suggest? I've not much experience with grounding; the only other component I have grounded is the Uptone EtherRegen. I'm using an AudioQuest Saturn grounding cable for that.
Audioquest Tornado seems to hit it right home for me, but the price is a little steep.Was just tyring out different power cords with the wa33. Triode Wire Labs Obsession and AudioQuest Tornado source.
The TWL pc has amazing transparency, clarity and air. A bit more forward and some emphasis on the highs. Very sharp leading edges and some glistening up top. Low end is tight and punchy.
AQ cable on the other hand has a smoother higher registry that is more pleasant to listen to. Also, there is a slight emphasis on midbass and bass, but low end not as tight as TWL. Soundstage width seems slightly wider with the AQ.
If more into detail and cleanliness, TWL. If going for an "easier" listen, AQ.
@Roasty Had you the chance to compare the AudioQuest Tornado to a Triode Wire Labs Digital High Power, which supposedly has also a smoother sound ? Thanks
@Roasty sure no problem. And compared to the TWL digital ? ThanksHey there. I have the TWL Digital, but not the High Power variant. Sorry!
