Andrew_WOT
- Jan 18, 2004
Spray adhesive worked pretty well, was afraid to mess everything up, but it turned out much better than I expected.Yeah, had them for a while, still contemplating if moving mesh screen from stock grill is worth it, technically it might negate the effect of the open grill mod.
Used this one Scotch Super 77 Multipurpose Adhesive Spray
- Peel screen mesh from stock grills
- Use rubber gloves
- Do one grill at a time
- Position grill on a paper towel, shake can well and spray from 8-12", make sure to have some adhesive mist on all parts, do not overdo
- Move sprayed grill to clean paper towel
- Carefully align with tweezers stock mesh over honeycomb, try to get it right first time so you don't have to reposition
- Use something like butt of screwdriver to press mesh in place
- Do the other grill
Turned out pretty clean with no overspray.
