One of the first things I did was to change the incredibly uncomfortable headband, I have no idea wy hifiman just didn't keep the he6se headband
HifiMan HE6 V2 Adorama
- Thread starter Kevintj604
What did you replace it with? I'm considering getting a set of ZMF headband + gimbels, as I really like the comfort of my ZMFs. I know some folks have used Audeze, but it seems like it's a crapshoot if you can get all the parts.One of the first things I did was to change the incredibly uncomfortable headband, I have no idea wy hifiman just didn't keep the he6se headband
Audeze carbon fiber headband
Shane D
But they are SO comfortable. And that is what I want when reclined in my lazy boy blasting the tunes.I strive to be objectively function-over-form with this hobby but man, those nuggets look silly.
Zmf headband will definitely workWhat did you replace it with? I'm considering getting a set of ZMF headband + gimbels, as I really like the comfort of my ZMFs. I know some folks have used Audeze, but it seems like it's a crapshoot if you can get all the parts.
bagwell359
Adorama has about 15 "open box" HE--6se v2 listed at $555. Been stalling to see XS available in the now in the US with a warranty.... Thus the v2 looks like the pick.
deafenears
Does ZMF sell the headband and gimbals on their own?Zmf headband will definitely work
hottyson
- Oct 8, 2003
I just got another pair of HE6se V2. It sounds very narrow and lacking dynamics compared to my old pair. At first I thought something was wrong with my Questyle CMA Twelve amp. But then I switched my old pair onto the Questyle and the magic returned. I guess I shall let it burn in overnight and check it again tomorrow.
I know they sell the gimbals and the rods because I was going to replace the ones from my VC before I sold it but you might have to own a pair of zmf headphones. That's the problem with audeze, they sell the headband but to purchase the gimbal kit you have to provide a serial number for one of their headphonesDoes ZMF sell the headband and gimbals on their own?
r343
- Nov 29, 2016
I have started to second guess if my pair of HE6se V2 was bad batch or faulty, soundstage was small and dynamics flat as heck unless blasting 80 decibels or so volume , tested with plenty of amplifiers ranging from 2 to 10 wats but no remedy.I just got another pair of HE6se V2. It sounds very narrow and lacking dynamics compared to my old pair. At first I thought something was wrong with my Questyle CMA Twelve amp. But then I switched my old pair onto the Questyle and the magic returned. I guess I shall let it burn in overnight and check it again tomorrow.
OkPsychology
Yeah, I've wondered this myself. There seems to be a tremendously wide range of opinions on these cans, especially as it pertains to the low end. I'm curious if there really is wide variance in FR from unit to unit, or if what one listener considers "good, well-extended bass" is just their opinion, and could be considered "anaemic" to another. But it's funny because you don't tend to get the same range of opinions with other headphones, at least not to the degree you see in reviews of the HE6seV2 (just a for instance, but doesn't pretty much everybody agree that LCDs have excellent bass extension?). I'd love to hear a few others' units to get some clarity on the subject (Boston-area HE6seV2 enthusiasts meetup at some point perhaps?)I have started to second guess if my pair of HE6se V2 was bad batch or faulty, soundstage was small and dynamics flat as heck unless blasting 80 decibels or so volume , tested with plenty of amplifiers ranging from 2 to 10 wats but no remedy.
I'm running mine off a recently acquired Ragnarok 2 and tweaking the output with a Lokius, like a few of the rest of you. Was using a Liquid Platinum before that. And off the speaker taps on a Denon integrated amp before the LP. I happen to really like these a lot, and think the Rag has the best grip on these drivers, though the LP really does hold its own in this respect. In other words the Rag isn't $1000 better than the LP by any means.
Re: the hotspot at the top of the headband... yeah I'm also dealing with this. It sucks. But after a few months of storing them on a homemade headphone stand made from galvanized pipe, I've managed to wear a small, permanent dent in the very center of the band, and it really has helped to alleviate that brutal headache these tend to produce.
Great thread, all. Glad I finally got caught up so I could contribute without being off-topic and out of date with my comments
dstarr3
Hifiman QC strikes again, it seems
Given that the gimbals are the hardest thing to find, is there any reason I couldn't just cut the stock gimbals off of the part that runs into the headband, drill a hole in them, and attach Audeze yokes to the drilled hole without having to try and track down someone selling gimbals?
EDIT: I'm thinking this wouldn't work terribly well since the clamping would end up way too low... unless I used a centimeter or so worth of the metal that goes out from the gimbal to the headband, and put the hole + yoke in it.
You actually can but you would have to reverse the gimbal and bend them a bit but you have a great idea. I will attach a picture for reference and I measured the space for the hole on the hifiman gimbal and you have more then enough spaceGiven that the gimbals are the hardest thing to find, is there any reason I couldn't just cut the stock gimbals off of the part that runs into the headband, drill a hole in them, and attach Audeze yokes to the drilled hole without having to try and track down someone selling gimbals?
Thanks! That's exactly what I was envisioning in my head.You actually can but you would have to reverse the gimbal and bend them a bit but you have a great idea. I will attach a picture for reference and I measured the space for the hole on the hifiman gimbal and you have more then enough space
