zima500
- May 12, 2009
Is there a DIY fix for this? Can't I resolder that side and lower it?
Just want to make sure this issue is not the standard. Don't want to go down a return loop.
Your he6se v2 does not have this recessed socket?
Have you thought about using the Dekoni choice suede for the LCD line? They are supposed to be very close to the old Vegans that everyone bought up for the m1060's.After listening to Dekoni HiFiMAN sheepskin pads for a while now, I put back on the Ether angled pads.
The sheepskin pads were great at calming some of that upper treble intensity, however they're a little honky around 1kHz, which I find to be a very annoying frequency. The pads are shallower, and in addition to the honk, the soundstage came in a little bit.
I also tried Dekoni HiFiMAN velour pads - while they aren't honky around 1kHz, the bass is rolled off a bit in the sub area and the overall tone sounded very dry. Not necessarily a bad thing, just not what I was after. Everything the velour pads did, the sheepskin ones did better, and the lack of honk didn't outweigh the improvements.
I really wish Dekoni would make a Choice Suede version of these pads, because those things are freaking magical. I have Choice Suede DT pads that I can put on, but they're so good on my MrSpeakers Ether that I don't want to lose out on that.
I have ZMF Suede and Dekoni Fenestrated Sheepskin TH900 pads incoming, and I will report my findings.
I had a pair, and geometrically speaking, they weren't going to fit for me. With the Ether angled pads, I have the headband extended all the way and could still use an extra click.Have you thought about using the Dekoni choice suede for the LCD line? They are supposed to be very close to the old Vegans that everyone bought up for the m1060's.
The Ether 2 suedes are also a great option, and are a perfect fit on the hifiman cups. They are a bit pricier, but feel and sound great on HE6
Ori, I'll let you know how it works out. I have perforated leather Ori pads and they're a perfect fit.Which ZMF suede are you getting? I have a pair of oval suede that I actually really like on the 6se. Maybe it is the added thickness I like. I want to try the oval in cowhide or lambskin.
The Dekoni Choice Suede is its own thing. For better or worse - and would be better on the HE-6SE, there's a consistent and significant reduction around 9kHz and only 9kHz. If you have a zizzy and zazzy headphone, they're just what the doctor ordered. I put them on an LCD-4 and it became insane chocolate goodness.
I've got a spare set of those Dekoni TH900 fenestrated pads that I have been trying to release into the headfi world for awhile. I really like them on the HE500 but I don't need two pairs anymore.After listening to Dekoni HiFiMAN sheepskin pads for a while now, I put back on the Ether angled pads.
How would you describe the change? Fenestrated pads change the sound wildly depending on the headphone. There's usually a bass reduction, but sometimes it's like -21db, and sometimes it's 1 or 2I've got a spare set of those Dekoni TH900 fenestrated pads that I have been trying to release into the headfi world for awhile. I really like them on the HE500 but I don't need two pairs anymore.
Its been a few years since I had the stock pads on but I do remember no bass decrease at all (it remained my bass standard up until I got the qualitively better LCD3 which has less of a midbass hump but more subbass extension), blacker background and a slightly wider/more open sound as well. Also, if I recall, a slightly more refined treble.How would you describe the change? Fenestrated pads change the sound wildly depending on the headphone. There's usually a bass reduction, but sometimes it's like -21db, and sometimes it's 1 or 2
Welp, got my RMA set back. Took a bit over a week. I sent it to them insured priority, they sent it back first class....but I think the headband is worse. What do you guys think? ooooof!
