toddking777
Thanks. I have never soldered before, but I am pretty darn sure I can handle this.
Thank you again for all of the advice. I wish that the cable on Ebay to connect the Hifiman headphones to the speaker taps on the McIntosh cost a little less than $160. I have a tube preamp (PrimaLuna Prologue 3) and am thinking of putting it in the signal chain. Once I do this, I will report the results here.
Great! You get to solder large wires to big terminals, and the banana jacks are held on by friction anyway. Heck, you can even leave the wires bare!Thanks. I have never soldered before, but I am pretty darn sure I can handle this.
Thank you for recommending Ted to me. I contacted him and ended up ordering a cable from him.You can also try one of our members who makes cables - Ted @ headphone lounge is my go to choice. He's made three of these cables for me over the past few years, along with recabling multiple headphones and his pricing and service are excellent.
Hey HP, good to see people "try it for themselves". The quality of the power supply is what makes the difference. More wattage works because of the ability of the power supply to handle the load, not because of the wattage. Power supplies need good components and the better you provide, the better the sound. IMO
The inefficiency can be a pro for those that have speaker amps/setups already, like those that mentioned earlier that they are powering the headphones from their McIntosh amps. This way you don’t have to invest in two separate systems.Even at $699 for the HE6e I'd still go for the Sundara. The 6e is just way to inefficient and finicky.
My Mjolnir did 5W into 50 ohms and didn't hold a candle to my Bryston.Has anyone tried these new Schiit Jotunheim 2 yet? On paper it seems pretty powerful with 4W @ 50 ohms
Interesting point. They are trying to sell off the new jotunheim as using discrete parts, and Mjolnir probably used discrete components. The question would be is the new jotunheim just another revison with tacked marketting and how it compares to Mjolnir would tell is.My Mjolnir did 5W into 50 ohms and didn't hold a candle to my Bryston.
In my experience, the HE-6SE sounds best with as low preamp gain as possible, and as high power amp power as possible.Interesting point. They are trying to sell off the new jotunheim as using discrete parts, and Mjolnir probably used discrete components. The question would be is the new jotunheim just another revison with tacked marketting and how it compares to Mjolnir would tell is.
