f97zhh
I got mine v2 this afternoon. I think it's only a headband design change. The sound are generally the same compare to the v1 which I sold to my friend.Thanks. Do you know how it may differ from the 'norma'l HE6se?
Do they have clamping issues? I have the deva, which uses the exact same headband, and it has little to no clamping force. If I move my head just a little bit they feel like they're gonna fall off.Listening to the new one right now, just came in today.
Overall I like the new headband better than the previous one. It has cup swivel for those wondering, very similar to how Focal does it. Maybe 20 degrees of pivot. Had them on for maybe two hours, no hot spots, no real issues except the stock pads, they don't feel that great.
First impressions are pretty strong. This is my first time hearing them stock.
IIRC in an earlier reply you said the size of magnet is different between SE and OG HE6? Any proof of that?It's really rock solid on definition and stuff I care about like overtones. Bass is very good, not technicolored like the HE-6 can be at times. If it had the headspace like my modded HE-500's I wouldn't be so hot for the Susvara.
The other day in the Arya thread I mentioned they along with the HEK v2 were better than the Arya, and an Arya owner was surprised about my 6se opinion. I'd like to have both - but if left with one or the other I'll take the 6se. I would take the HEK v2 over both however - easily.
Any pics of the drivers? Would be nice to see if theres any visual difference between the two versions
I've got the ZMF Autuer perforated suede pads on my HE500, they are quite similar to the Audeze suede pads that people used to love on the HE500/HE6got mine today, looks like they removed all the dampening, and swapped the headband is the only difference from the original he6se. now to figure out what pad route im going to go...
is there a "warmest" pads I can go with? Just ordered some rings so may see if any of the ZMF pads I currently own work well with them if I can figure out anything.
My current favorite pad is the Ether 2 stock pleather pad. The adhesive surface makes for a complete seal and its the perfect size. The pads are firm and retain great bass extension and impact. I was able to pick them up when they were on sale a month or so ago for 60ish dollars, still on the high side, but better than $90. I am using these on original HE6, but also loved them on the HE6SE I previously owned.got mine today, looks like they removed all the dampening, and swapped the headband is the only difference from the original he6se. now to figure out what pad route im going to go...
Yep. Here is a picture completely stock. Just removed the ring/grill.My current favorite pad is the Ether 2 stock pleather pad. The adhesive surface makes for a complete seal and its the perfect size. The pads are firm and retain great bass extension and impact. I was able to pick them up when they were on sale a month or so ago for 60ish dollars, still on the high side, but better than $90. I am using these on original HE6, but also loved them on the HE6SE I previously owned.
So when you take off the back ring you are saying there is no damping material behind it? I do not remember if the HE6SEv1had any damping on the back side of the driver?
Sorry I probably remembered it wrong. I myself have a 4 screw HE6, brought em to a meet and AB'd an HE6SE. The SE doesn't slam as hard as the OG 6, but the difference, all things considered, is not that big.I did say that about the HE5se, I do not recall saying that about the 6se. I have talked about the change in pads, material used for the body, cable, membrane, headband making a big difference in the sound. The traces, stator, rear screen appear unchanged.
