It's really just subbass boost (look at attached file). At 50hz, it's barely +5db. It only gets significantly bigger at 40hz and below. Yes, I've done this test to virtually every headphones I've ever owned, including: HE-400, HE-560, Sundara, and several dynamic driver headphones (the dynamic drivers all distort like crazy). They all passed, except the first Sundara had an issue. For the first Sundara, the right driver began to permanently malfunction after the first extreme subbass test through my THX 789. My second Sundara passed the test with the 789 maxed out on high gain (at some point, the amp showed its current limit).
The difference between those headphones and the HE-6se is that the 6se eats far more power. My worry is that even though they're extremely inefficient, they might not survive more 5-10 watts in the low bass region. That could be a design issue. If these headphones are supposed to gobble up lots of wattage, they need to be robust! If you think about it, 2 watts into the Sundara is roughly equivalent to >20 watts into the HE-6se. You can pump 2 watts of subbass into the Sundara without an issue (specifically subbass only, else you'll destroy your hearing fast). 20 watts...Well, if you've ever touched a lightbulb that outputs even just 14 watts, you know how hot it gets!
Therefore, I'm considering that maybe the 6se just isn't designed to output as much decibels as Hifiman's more efficient models in the lowest octaves. This is a shame....I really loved its well defined, quick bass. When I'm watching a movie, I do sometimes like to turn on the 18db subbass boost, just for fun. Now, it seems the 6se is only fit for music listening with a much more tamed boost.
