Fegefeuer
- Mar 17, 2011
@DarginMahkum has iirc
I own a HE1000SE and I really like it so far. However, I am still running the headphone directly on my iPad, which is not very convenient.
Now I have the chance to buy an used T+A HA200 for a really good price and I am wondering, if this amp would be a good match for my HE1000SE.
I have the HA200 and HEKse and it is a superb match. For planar HPs the 1/8 rule does not really apply, as the impedance of planars is flat, unlike dynamic HPs or hybrid IEMs. So it does not effect the frequency response.Hi there!
It seems that the lowest output impedance the HA200 can be set to is 8 Ohm. With the HE1000SE having an impedance of 35 Ohm, this pairing would be a violation of the 1/8th impedance rule.
What do you think? Has anyone tested the HA200 / HE1000SE combo? Is it still a good one, despite the 1/8th rule mismatch?
And what is the technical explanation for that?I know that the HEKSE sounds good with amplifiers that have a low output impedance.
@irishnutter also has the same HEKse + HA200 duo.I know that the HEKSE sounds good with amplifiers that have a low output impedance. However, I wasnot sure wheter it sounds also good on amplifiers with a high minimum output impedance, like the HA200 with 8 Ohm as its lowest setting.
Thanks for your answers! No I am really considering the HA200 for my HEKSE.
Yes, I'm very happy with this combo as well - although I think between the tone controls, impedance control and the digital filter options, the HA-200 will synergize well with many headphones.@irishnutter also has the same HEKse + HA200 duo.
Does the Susvara have as wide tall and deep a sound stage compared with the HEKse when properly amped?I would descriptive the HE1000se as very open and revealing with a flat frequency with only a minor dip between 500 Hz and 2 KHz. The dip is indeed minor and I would guess around -1 dB. The minor dip is however notable because many instruments and voices have their foundation at this frequency. The treble is clear as a day but with the “wrong” upstream gear or records it can be a bit rough. Susvara for example is smoother and more forgiving on bright and harsh upstream gears and recordings.
The HE1000se will IMO not mate very well with upstream gear that is on the bright and lean side. The rest of our audio gear can either keep, enhance or subdue the sound of the HE1000se.
I think Susvara just better headphones in all aspects , including soundstage, just you should have real powerful amplifierDoes the Susvara have as wide tall and deep a sound stage compared with the HEKse when properly amped?
HFM mentioned mine was the latest edition. The box says 2021-10-29 on the Chinese PASS label, I assume that means these were made thereabouts. I wasn't aware of revisions -- what were they?Did you get the new revision? I am pleasantly surprised about the one I have here which despite the same chain where the brightness was very obvious sounds, is notably better behaved in the treble, more linear/even, cleaner. The first one I had was a 2019 model.
Sure it's not very surprising given the many Arya revisions and the Ananda probably got the same treatment as well but still.
It is still a brighter headphone but it doesn't make me rip it off in disgust anymore. Instead I really enjoy it.
I briefly tried the 1000v1 and have yet to compare it directly to the SE, but from memory the SE comes across as more convincing and natural in the treble area.It certainly has a lot more energy than my OG HE1000, but I find it much more engaging.
