Fegefeuer
- Mar 17, 2011
It's interesting the warranty policy states the HEK being 3 years but nothing about the Susvara.
Impeccable observations, which line up exactly with my experiences! Good ears sir. I may add that indeed HEKse portrays significantly more height, but Susvara really does project depth better, and has better crossfeed/ center stage.I don't have much time to post these days but just thought I'd throw in a data point. I like the HE1000SE with the Silver Dragon nearly as much as the Susvara (same cable). It actually does better for some genres like hip-hop, pop, and some electronic. Might also be better for movies.
Some stream of thought comparisons below:
-Susvara is more balanced/neutral with a greater emphasis on mids, so vocals sound more upfront and larger. This also makes it easier to pick out microdetails in the mids (but I don't think it's due to superior resolution). I don't find any part of the Susvara sound signature untoward and it lends itself better to higher-volume listening.
-HE1000SE has more bass (more than neutral with the stock cable) and slightly more mid/upper treble, a taller overall sound/headstage and it sounds more distant in contrast to the Susvara's more upfront presentation.
-Susvara is a little more open-sounding. It feels like it has less material obstructing the drivers from the rear, which actually seems to be the case.
-Susvara has less bass but it punches harder. I find the treble to be more revealing and here I do feel there is a resolution advantage. Susvara also changes a little more from recording to recording, ie. it's more transparent overall.
-Speed is similar with the Susvara being a little faster (sharper attack and quicker decay). Macro and microdynamics (other than in the bass) seem pretty even, as does bass/treble extension.
-HE is much easier to drive, but the Susvara seems to scale up better. Once I get the EX-M1+ (on the way), I can add more info on this.
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
Why is no 3rd party making pads for the big hifimans?
What, the HEK?
why? whats wrong with the HE1000se pads? I thought its pretty durable and comfy...
They feel cheap flimsy and are not durable. I had my HE1000 pads literally disintegrate after 1.5 years.why? whats wrong with the HE1000se pads? I thought its pretty durable and comfy...
How many years did you have them?They feel cheap flimsy and are not durable. I had my HE1000 literally disintegrate. Dekoni makes worlds better pads.
One of the HE1000 series’ main weakness is the lack of center focus.
