MrHaelscheir
I guess it is indeed a matter of different ears and perception. For me, with almost any pair of headphones (what few I have tried), say, the Jabra Elite 85h and ATH-M50xBT, the pencil starts somewhere on the left driver, maybe a specific centimeter or few beyond it (generally the same position between these headphones), then progressing backwards up to the plane just behind my head as though writing upon a table that intersects my head, then progressing to the right behind my head no more than three centimeters, continuing straight to the right then I guess by some hearing artifact arcing backwards behind the right driver (I guess a recording can only simulate traveling deeper into a driver so much). It is very similar to me between the Arya Stealth and Meze Elite, and I've felt like the size of the trajectory was likewise similar on the smaller headphones, but merely more "obstructed" and hence "intersected through" by the smaller pads and closer drivers.The pads are identical. Clamping force is just slightly higher on Arya. This can have some effect but not this much. I used Arya for over a year now and the soundstage was always my complaint about them. I'm very used to them. Putting on HEKSE, the stage/imaging difference is just immediately noticeable apart from loudness or the tuning scoop. I eq my headphones and i can get pretty high score from Sean Olive's ''how to listen'' software. So i can recognize frequencies and their effects to some degree. The difference here is quite obvious so i think it can't be relegated to slight loudness or midrange scoop difference.
That's a nice track. On Arya Stealth, it starts at my left eardrum and goes to my right ear from the back of my head, creating an arc. HEKSE does the same thing but more obvious and slightly more distant. It creates a bigger arc. Arya sounds like it's inside of my head, very intimate. HEKSE just slightly outside of my head. I also tried dolby atmos 7.1.4 demo. HEKSE just have better imaging contrast and space. It's like the aspect ratio of the sound is different if that makes sense. Arya is narrow and tall, HEKSE have more horizontal space. It's like 4:3 vs 16:9 aspect ratio. HEKSE also creates space between things.
I will test out more. I will eq them to harman and see how they do like that. It's time consuming because i have to switch earpads and HEKSE's earpad clips are quite secure.
Now, this track truly astonished me the first time I heard it through the Meze Elite when the sound source at times sounded ridiculously far compared to the other headphones I was auditioning, though that effect was tamed to be more similar to other EQed headphones upon later listens:
Basically, for me, nigh the entirety of the "soundstaging" in the sense of "image size/staging" is within the recording itself, the rest purely being a subjective sense of more space around my ears or a "bigger" sound clearly coming from a larger driver.
