I used to believe that break-in was BS, but my Sundara actually got better with time: a little less sharp (to the point it's not sharp anymore), a little better on the bass and a bit wider. My hd560s, on the contrary, did not change much (so I don't think it's brain burn-in).And it will just get better as you break them in.
Also my Focal Listen did not change very much. Not sure about the Beyer.
Maybe it's about the pads? The 560s has some kind of velour which did not collapse at all, while my Sundara pads changed a lot. Or maybe it's the diaphram?
