mintshows
You could definitely get a 3.5mm -> RCA cable to go from the MOJO to Lyr input. You'd want to probably have the mojo at max volume in this case. That would save you another $100 for not having to buy the DAC module for the Lyr, but obviously a little more 'fussy' of a solution100$ less fine by me Alright I see what you're saying, the USB Unison is a better option for a built in DAC.
I plan on going with an amp with a built in dac anyway, but could you possibly clarify the Mojo/Lyr combo I saw someone mention they're using with the Arya...both are amps with built in dacs already, how exactly would that pairing work and do you think it would be a good one (I already own a Mojo so if I could still get some use out of it that would be fantastic)?
