In my experience, the cushioning of the Serenity Pads for my Arya v2's were considerably stiffer than the Ultrapads for my Arya v1's; I received the v2 after RMA'ing my v1's for a fee (my fault). I obtained another pair of Ultrapads from Hifiman and thankfully the comfort was the same as the one's from my old v1's. The Serenity pads were unbearable to wear and caused jaw pain for me. The Ultrapads, on the other hand, are supremely comfortable and I could wear them all day, YMMV. All I had to do was to cut out the dust cloth from the Ultrapads (the v2 already has a dust cloth covering the drivers).
Thank you! Mine Arya is V2 and maybe that it is. I wanted to try my used Anandas pads on Arya, but they doesnt fit. All reviewers considered Arya as very comfortable even super comfy so I've not worried about this before purchase and after excellent experience with Ananda BT that I can listen for hours and I forget that I've HP on my head. Maybe I can bend/straighten head bridge a little to weaken that clamping force, but I'm afraid of damage of 2 day old Arya....
Hmmm, I do recall that the Ultrapads (same pads used the v1 Anandas, HEX v2, and HEK v2) had a little trouble fitting at first, but I managed to do it. The clips did require a little bit of finessing to snap into their holes. Just take note of which clips are the problematic ones, insert those in first, and be patient when trying to snap the other ones in without overdoing it. I don't know what pads that the Ananda BT uses (does it come with a dust cloth attached?) and I wouldn't recommend bending the head bridge (believe me, I've tried).
Thank you, I've moved one click up and positioned HP little bit lower on my head and pushed pack as advised. It is better but not good. After 1.5h of listening clamping force became unbearable for me.
Shipped them off just now, wanted to insure them but insuring Aryas at their retail price would require a signature and it clearly says not to require shipping when RMA'ing, so now here's to hoping it gets there without issues, had to only put $500 worth. Other then that, so far so good from the Hifiman team :] Better support now then back when I had bought the original HE-400's in 2012 for sure.
Hi, why don't you recommend head bridge bending on Arya? You was not able to bend it or you was and it didn't helped? Or have you damaged it by bending? I was able to fit one earpad (half way) from Ananda BT on Arya to observe differences. It was better but not perfect. ;( I think Anada Bt has the comfort pads, photo attached, what do you think? They didn't look that different to me aside attached dust mesh. Thank you very much!
Hi, personally, when I bent them just slightly I noticed how that the top portion of the pads were catching the underside of the gimbal more. Too much of it catching will block the pad from swinging laterally, which may lead to the situation that I kind of have with a HE-560 headband with the formation of pressure against your temple. I wear the comfort strap three clicks from the bottom. All of this is from personal experience, so YMMV.
As for the Ananda BT, it is clear that there are more holes provided on the Ananda-BT to secure its pads. In other words, the Ananda-BT pads have more clips, which make them unsuitable for your Arya's. I just checked the clip configuration of the Ultrapad that is on my Arya v2's and it is the same as the stock Arya v2's pads pictured in your post.
My pair of Arya's has a dark cloth-like mesh over the driver so does that mean it's the 2 revision?
I've heard the original ones had a metal mesh covering the driver which mine do not. Either way they sound great but it's weird that Hifiman keeps doing small changes to some of their headphones and not say anything about it even when the sound signature changes. I think it's good they're always looking to improve their products but I feel like they should say so especially when that change is to the sound of the headphones no matter how small the change may be.
I'm not sure if Hifiman withheld the fact there was a revision (did they?). Their website certainly makes it clear its the version with the dust covers. I agree though, if there are appreciable changes to sound signature people need to know as quite a few reviews are based on Arya v1. On that note, I have v1 and have been very pleased indeed.
Pairs brilliantly with the Jot2 and suprisingly well with the portable ifi Signature DAC/AMP.
