music4mhell
- Dec 7, 2015
I used it today for first time ..Has anyone tried using ap60 as source to use for walnut v2 as amp? Any success?
I'm curious...what level do most of you listen to your AP60 on (on average) using IEMs and unamped. Anybody??
Has anyone tried using micro usb otg+usb to 3.5 mm jack for connecting walnut and hidizs ap60? I don't know if it'll work or not
I'm guessing it wouldn't work. I plan to use Ap60 as source to walnut but using 3.5mm would be double amping.I am not getting, Micro USB to 3.5 mm ?
One side is digital and other side is analog. What are you trying to achieve ? Please elaborate your requirements !
It was good and loud, power enough to drive HD650 nicely
I listen at around 23-25 high gain. Depending on iem, if i use Havi B 3 have to increase bit more.
With Monk+, i use volume at level 40 around with low gain setting.
Wow! that's half the volume isn't it? It has 80 steps right? Are they hard to drive?
May be my ear is sensitive and also i enjoy listening to music at low volumes... yes it has 80 steps, but for HD650 i had to use High gain
