You should change the topic title to something more informative IMO.
So.... may I ask why we are discussing about the topic, which is already repeatedly beaten to death in hydrogen audio forum..... since as early as 2003?
It was very clearly answered multiple times, yet after 8 years later, we are still debating already answered topic with such passion.![]()
Hello~~
Thank you for this informative thread G. I lack the background to fully understand all the arguments here, but I learned few things
So are you suggesting that devices like hiface is over-hyped and won't make a difference in the listening experience?
Most DACs & soundcards I see (m-audio, Ayre, meier-audio) just to name few, all advertise playback of upto 192khz...
Now, I'm beginning to question the credibility of all these brands/manufacturers.
I use my computer to listen to music on HD650 & Old Corda Ha-I Mark II, but I lack a DAC.. so I'm relying on Terratec DMX 6Fire 24/96 which is way outdated... and the EMI is audible.
Therefore I am considering buying a DAC & a sound card that outputs digital in order to eliminate this issue & upgrade my setup.
What should I really believe? and I apologize for my ignorance and lack of knowledge, but I'm willing to learn
Thanks,
Originally Posted by wnmnkh /img/forum/go_quote.gif
If you have desktop and have some internal space/slot, grab some studio-oriented DACs. They are ones that can actually handle 24bit signal from USB (which most of consumer-oriented DACs don't.) and they are quite cheap for what they do.
Search for brands like E-MU and M-AUDIO.
NOS DACs if you are looking for an accurate (linear) sound reproduction. Remember that in the audiophile world high price often doesn't translate to superior sound quality. Beyond that, there's not much I'd suggest except to try them out and take what sounds the best to you.
Ask away if you have any questions or concepts you're stuck on. Quite a few knowledgeable people round here willing to help.
EDIT: Just seen wnmnkh's last post, all good advice in my opinion!
G
I have many questions but I'll keep mine on topic in this thread.
I'll summarize what I learned in simple language:
* 16-bit precision input to DAC is perfect for the job for 'red book' standard. Therefore, no point in any higher precision or sampling as an input to DAC.
* Inside DAC, doing sampling 24-bit or higher is better to avoid creating artifacts? (not so sure about this).
Now to add more to it, we are talking about stereo playback, i.e. CDs and "red book standard". There is SACD which is a different standard than PCM and also as far as I understand requires multi-channel setup..
Doesn't this mean that CDs aren't the best standard? Although for CDs going any higher than 16-bit & 44.1Mhz is pointless?
Finally, any recommended 'introduction to audio' papers or even a book? I have one but it was too focused on hardware, rather then theory.
Thank you!
Hello~~
Thanks,
What do you mean when you say the EMI is audible?
Your first starred point is correct, the second is not (or maybe under certain circumstances). Try reading this post as an intro to bit depth.
SACDs don't require multi-channel setups, the vast majority are stereo. SACD is based on a closely related technology to CD called DSD. SACD only uses 1bit of bit depth but at very high sampling rates. Ignore learning about SACD until you have a better understanding of PCM (the technology of CD).
Best book on the subject is "Digital Audio Explained: For The Audio Engineer" by Nika Aldrich.
Look for articles online by "Hugh Robjohns", the Technical Editor of "Sound on Sound" magazine. Try these to start with, it's quite old but still good.
Get back to me if you have any questions.
G
What I want to know is that, do you need a multi-channel setup to enjoy SACD or headphones would work on them?
From what I read also that PCs cannot play SACD to their benefit.
As far as I know, the vast majority of SACDs are stereo, so should work fine with headphones. SACDs cannot be played back by any type of CD, DVD or BluRay player, you need a player that is specifically designed for SACDs. I'm not sure if it's worth investing in the SACD format now though, it doesn't look like it has much of a future, new releases are becoming rarer. Remember, the SACD format is not intrinsically any better than 16/44 or 24/96, it's just that the mastering is sometimes better. Maybe others here have a better idea than me on the future of SACD?
G
Wait, you saying DSD used by SACD is worse than 16/44 LPCM?... Argh, do you have something to prove that?
By the way, physical high-def audio format is dead. Digital is all the way (Linn Record said 90% of their 24bit are sold digitally. Similar figure for other music labels)
No, I didn't say SACD was worse than 16/44, just no better. There are both technical advantages and disadvantages to the SACD format compared to 16/44. However in a year long study by the AES with over 500 DBTs, using professionals and non-professionals, the success rate in distinguishing SACD from CD was almost exactly 50%.
G
I see. what I meant was about technological aspects of DSD and LPCM. For actual listening experience, surely no one can discern any difference.
