Is the output of the CDP from the DAC different from that on the CDC? I was thinking that I should get the CDC said:
Having owned a Nagra CDC for a year now, I was hoping my first ever forum post would be an informative and witty review of the little beast. But it sounds like you need an answer sooner than that. So here goes on the specific question:
The CDC is exactly a CDP, but with a preamp section grafted at the end. This gives much greater versatility, but at the expense of a slight drop in sound quality. The Nagras were so rare I could never compare both side by side.
Whether the SQ is important to you depends on your partnering equipment. One way of looking at it is that there is just over £1k’s worth of preamp in the CDC, which compares favourably with external preamps in the same price bracket. But it won’t match more expensive preamps. I can hear the sound quality of the CDC drop as the volume control is reduced. It’s not unpleasant, but just gradually softens up the dynamics and 3D soundstage. This is partly because the CDC is fundamentally so transparent that it’s easier to spot, but it does indicate that the preamp section has limitations.
That limitation can be reduced by maxing the CDC’s volume control and feeding a posh external preamp. This will bring it’s sound quality closer to the CDP, but probably not quite matching it. Sadly, there is no direct by-pass option on the CDC. Santa take note!
Perspective time: I auditioned the CDC against the highly regarded Accuphase 78. The CDC’s volume was set to -5db to match levels and both players fed a high quality Spectral preamp. Even with “the limitation”, the CDC won easily.
I personally value the versatility of the CDC over the potentially slightly higher sound quality of it’s cheaper brother. The CDC has a very good headphone socket that’s better than mid-range external head amps (I haven’t tried the super maxxed, extreme kind). I'd say live with it for a while, then compare with a top end HP amp. At least you have the choice.
Finally, when I’m spending an obscene amount of money on a tiny little box, my heart starts ruling my head. With the asymmetrical dials and the all important modulometer, the CDC had my name on it from the start. I’ve never seen a CDP in real life, but from the photos, it’s at risk of looking a touch bland. But fair enough if you prefer minimalist over lab-chic.
Richard
PS. The balanced section is grafted onto an inherently SE configuration. So SE should be better and I only have SE cables anyway, so haven't compared. Others have said that balanced is just fine too. I use SE to drive a Stax Omega setup.
