Drag0n
- Jun 11, 2004
Good investment is really a personal preference.
Of the amps out there, i "personally" like :
RSA: Hornet, Tomahawk, RS71 (classic version)
Meier: 3Move....or any Move model, Headsix, or any of Meiers common battery powered amps.
Portaphile: Portaphile Maxxed (eats batteries but sounds great) The Standard model doesnt eat batteries as much and is a great value if you can obtain one used in the forsale forum under $150 or so.
There are lots of amps not made anymore that you can find cheap in the forsale forum used that i happen to like, and own a few of them:
Shellbrook: MiniMoy, MaxiMoy, MiniHead
Z-Audio: Mu, Lambda, Epsilon
Practical Devices: They make a few models with many features with options of an internal rechargeable battery or a 9v alkaline/rechargeable. Theyre still being made.
Check Skylabs Portable Amp review. I believe hes up to about 50 amps now.
Then youll kinda get an idea how they compare and sound and maybe some quirks or features i dont know about.
Some of the amps i listed may not be on his list, and sure there are better out there, but you pay for that. Its all a matter of preference and what you want to pay. At certain levels, there isnt alot of difference between the amps really. Go to a meet and hear them.
There are many great amps out there other than what ive mentioned, and they have internal battery packs, but im on a kick lately. I have a T&D Xtra1 Pro amp here that i cant find a battery for now that the company is gone, so i can only use it as a desk amp now.
I also have a C&C Box+ that works fine, and i love the amp really, but im worried when the battery dies. I did find a robotics company that has a battery for it though, because someone searched and found it, so i know i can prolly fix that one.
So theres my reasoning. I feel its bad enough all the music players are throw-aways, but i dont want my amp to be a throw-away also.
Now you may say...."But so-and-so is a great company etc., and theyll replace the battery"......Ok, wonderful, but so-and-so company may go out of business and then youre stuck. But, for some people, they dont care....they will just buy another amp, or maybe they can solder mini circuits etc.
Originally Posted by carnival /img/forum/go_quote.gif Do you feel that it's a good investment? |
