Aug 23, 2012 at 9:26 PM Thread Starter Post #1 of 2
jasonb
does anybody have the sa6, sa1, or use these tips on any other IEM's?
if so i would just like to know the diameter of the bore, so i can see if these will work on a GR01.
also are they the same diameter on both ends, or are they bigger or smaller at the nozzle end.
Aug 23, 2012 at 10:08 PM Post #2 of 2
nvm, found the answer. looks like they are only 2.5mm. i'm assuming if i put these on the GR01 it would alter the sound. from my experience with the CKM500, wider bore tips brought out the mids and highs, so if i put a smaller bore on the GR01 it would probably hide some mids and highs. i really like the sound as is, but just want tips that isolate well and are real comfy so i can wear them for long periods of time. looks like maybe i can try the Meelec M6 bi-flange tips or maybe the UE bi-flange tips. does anybody know how soft the M6 or UE replacement tips from audiozone on ebay are?
