viola_jam
- Mar 1, 2010
The other day I was all set to balance my headphones using the instructions provided here: http://www.head-fi.org/wiki/tutorial-on-how-to-equalize-headphones
The first link to pink noise does not work anymore, but found pink noise on a different site, and a sine wave sweep that runs from 20 - 20,000 kHz's for 1 minute.
I downloaded the SineGen 2.1 program opened it and hit the power button and received an error message. I am running 64 vista (sp2), with the output set to: USB NuForce Icon HDP (Dac).
I hit the power button and I get the following Error message:
"The specified format is not supported or cannot be translated. Use the Capabilities function to determine the supported format."
O.K. so any ideas on where the capabilities function is? I have looked everywhere. I even tried the SinGen 2.5 version and received the same error.
Am I missing a step somewhere between opening SineGen and hitting the power button? I understand why I need the pink noise file, but I was not able to find instructions regard what to do with the sine wave sweep file in the wiki could this be the issue?
Thanks in advance for any advice you may have.
