rabellogp
- Jan 18, 2011
Hello, guys.
I have the following system that I use for every kind of music:
- Asus Xonar Essence ST
- Emmeline XP-7
- Sennheiser HD650
It sounds amazing but for electronic it's a little bit boring... I think I need something with more bass impact.
So I decided to get a second headphone for that. I'm trying to find something inside my country (Brazil) because it's so difficult to import that kind of stuff over here... =/
I've found a Beyerdynamic DT770 Pro 250ohms. I can't listening to them before I buy it (I'll buy over the internet) and I've heard that the 80ohm version has more bass than the 250ohm. The problem is that there is only the 250ohms on the store.
The amp is not a problem, I'm just worried about the bass quality and power of those headphones when compared with my actual HD650. I don't wanna waste my money with something with almost the same bass signature...
Does anyone has ever used both of those headphones and is able to tell me if there is a noticeable bass difference between them?
- Emmeline XP-7
- Sennheiser HD650
