Help with portable amps in the ~$100 range
Sep 22, 2010 at 9:05 PM Thread Starter Post #1 of 1
dmort
I love the look of the firestone audio fireye 1, but I discovered that it doesn't have a volume attenuator, and therefore can't work with line out. So I'm looking for other suggestions, in the $100 range. I'm hoping for something with a metal enclosure and a volume attenuator.
I'm aware of the ibasso T3 and the T4. After reading a few threads, it seems that the T3 is the better choice. Are there other models from other manufacturers I should consider?
I'll be using this amp with an ipod nano. I'm using ATH-ESW9s and HD 238s. I will be buying a LOD to use with this amp. Likely something from ebay.
Thanks!!
