el_matt0
- Feb 7, 2007
Hey guys, been awhile since I've been on the forums but I've got a custom sennheiser cable which I built awhile back that I'm experiencing a loose connection issue with. The connectors I used/purchased appear to be ever so marginally too thin to achieve a snug/secure fit into the HD-25 earcups (with split cable and the cups reversed, cables w/ downward exit).
I've tried a few rudimentary solutions like thickening up the cable side of the connector with 1 strip of scotch or electricians tape but neither worked very functionally. id like to avoid simply just gluing the thing in there, as the removable aspect is nice. Any suggestions on things to try? Has anyone else run into similar issues?
