sorry for the late reply I spent the weekend attempting the EQ proccess on my PC with my razer headset. again I do not understand anything and ended up just making the sound worse. I am not a sound engineer or a super high end audiophile. I am what some would say a normal person who has no idea what they are supposed to do and thus why the prefer AdaptSound. Heck if a company were to offer this as a service I would pay for the software
You don't need advanced understanding of it, I just laid out the instructions. Here they are in a line by line format if reading it off a paragraph looks confusing.
1. Download Equalizer APO.
2. Install Equalizer APO.
3. Equalizer APO.
4. Click the + and hit "Graphic EQ" and look in the menu options and make sure it's on Instant Mode so it applies the correction EQ when you save it.
5. Look at the frequencies in the graphic EQ's bands.
6. Google "free sinewave tone generator." This creates a constant sound similar to what you will find on Adapt Sound, but more like what's on Neutralizer for Android.
7. Install the tone generator.
8. Run tone generator. Look at Equalizer APO interface. Have both windows open side by side. If you have dual monitors you can put them in one each.
9. Depending on the tone generator it might create MP3 sinewaves (a) or just generates the tone straight out of the app (b), so adjust accordingly.
10a. Create sinewave MP3 files and input the same frequencies you see on the Equalizer APO graphic EQ.
10b. Run sinewave generator for each frequency on the EQ APO graphic EQ.
11. Run 1000hz sinewave. Then run a sinewave for the lowest frequency on EQ APO. Move the slider up for +xdB if the first frequency is softer than 1000hz, down for -xdB if it's louder than 1000hz. Then save the profile.
12. Repeat 1000hz, then return to the first frequency. Are they roughly equal? If not, move the slider again. If yes, move on to the next frequency.
13. repeat steps 11 to 13 for all the other frequencies on the Equalizer APO graphic EQ.
14. Listen to actual music. Is it how you like it? If yes, then you're done. If not, repeat steps 11 to 14 and recheck your work.
