May 3, 2021 at 5:13 PM Thread Starter Post #1 of 1
Ocsec
New York
So my AD900x have been great to me ever since I bought them but the only issue was that the wire was so damn finnicky and would twist on itself. Well my wire finally started ripping because of it twisting so I searched for a way to replace it and found this thread on here to replace the wire. I basically tried all day to get this to work but ran into a bunch of different issues. I got some audio to work like the left and both channels but not right. Then had issues trying to reassemble the headphones and caused the wires to break. Then cut out wires from the cable and combined wires with the ones in the cans soldered it and only some channels worked again. Then de-soldered the wires from the board itself and re-soldered with cut wires again from the cable and it still doesn't work at all. Any help with this will be greatly appreciated I really would love to have a detachable cable with these headphones, they've done me a great service thus far, I just can't figure out where I went wrong.
M4l_hlI1qWQLSX2ISYazYdvMx3fXdprhCasZvtAzyuQRJq6e8QySxNZ9T1v6O1_twcavx8S_miaEcS9R7HGI3d5SFaJiCtag1XrxUOl22HP2QPqj4IhiMG6okkyZ0-_In1BLEi16cqkIqufovlRnaVB8ped6MR2GZlQW-KmBaSEQD-7tiWhyyprthJeFaBCuRvbSIUYPx8Iw7b_LnPO9yhiCriMS3I16_yDpkrdj_zKPmzQEjRVrNUTbNYMLx_PxCvtCEjlF4iMl-UTGO2eDfDLgCXr0QjE7T06f4D0atPJpJNIfnRm0MBx3ir9GZZZ31pN8H2pP9yUTR67XHlAraqOsxBV1CZMFeRc2YuFIHC7ab4Ru9DTDrtoqk_cYtEy4sjbdkaBVhUx4zM5zzXr_u2Hbcx7CbVyFbSMDApXONpdXET0tl2ii3LDFVlOOjkUFVPGGuKHPKz-ZF7GXP29okymPNtmnR6J9TEwiITMWEQgHpR_c3isGigtmDAAldMOlnGg_ukCbPGAnRY-I20sxoQd7U2cFnnWGo967NB446ucfZm56kBcY96CzuBEoph4y7QqitcMYwlICOIRxxG5muq7CQRglFhvNjJzpTMGzhI9aMy5ya5OgOzwBzI34ct0ce4Iyam-Pzqwdvyd7cAuILzPGLZrMEgvjBXigsN_6m3xWWqvVLfBpxwrtGaIxUFNbzsrid37D1TZQp8wQVOgnzStJ=w528-h937-no
mZ0nBTHRt-BoQ9spzuWQv0mfix-v0fAFWD9k4h-6BTZz1z15U1xnrhatN_v33h1R67vvJECkKwdoZtl53pd8CVLTSLSLnALkdXw2Y21jeeUpUyXrOUT1d363qEEVX3c3Fj7GIgTgjHvCRjEPG4iFGOuxxMPHmfpAUCZz_dYExsZo1c20VkGR4lQEcIkL59NiCSZLjjzJwn_D3v7jXmB8XQkn3ABDAV5EHto2IDwTI8umvApZoPyOvNvh5WU4HhpZdDfrcdqFHCWoWSGEUfgCy3R3FJx_vImwOWCewqXWiIzceudLbWOokPR9x0r40Y5UFoUB9Z9ub-v4WbekL24VcEmaibLHzDoH1F7g91vnkz1n4ooIvuXsetQ8prqRGorNXvZLR64L78iI-djEA7q4Ypw56ffjCLY8FDFj9tWKAskJZ2rUtE9hiFM6ubwLGYvs3PTJq1FMNqJZYhj6qd6if2YNF7TUdu0xRvadfwViEFyLAMpRlbPsQl_u7ZWZHYTxl7GPI4M2llEwT0lyO6iKf9fOCotIpyq1ZutJsj-pHKzvtAJ6hWImi4HeZbaVpAxbL8_BLOAOmPbfTqMrTD6Vz83CCdhaaIdzmAB_kx-QsyjwiphTAR2mq-8aY3qzpCaGBl_JWgQSmWFyzWDDxYdNcBLY_F6Czx3iC11OPyRjvt5tAV5Tb4U3FmJMt6piFaVWOk-OaiaKGW3CJ85lyouq2Wqu=w528-h937-no
Link to the audio jack I purchased
