Aguirre
- Jan 27, 2007
Hello
I built an amp with an AlienDAC running to a PIMETA. The PIMETA is powered from an external dual voltage power supply. The AlienDAC is powered directly from USB.
Originally I had electrolytic output caps in the AlienDAC and no input caps in the PIMETA. There was no problem with DC offset that I noticed. The sound was better than the integrated audio from my computer, but still not so great.
I then removed the output caps from the AlienDAC and jumpered across their postions on the PCB. I cut the traces on the C1L/C1R positions on the PIMETA board and then installed 4uf 200v Audience Auricaps. The sound is easily ten times better.
Ok enough with the lead in, here comes my problem. When I measure DC voltage with music playing it is about 5-10 millivolts. BUT when I turn the volume pot DC jumps up into the volt range. Like 3 or 4 volts worth. And then takes maybe about 20 seconds to come back down to several millivolts. I am using the ALPS blue velvet which installs right into the PIMETA board.
I wanted to know if this is normal. I don't seem to recall this happening when I had the electrolytic caps but I don't know if I actually tested for it before. Also if this is unusal, would it make any difference if I moved the caps. Right now signal comes to the pot first and then into the caps.
Altogether I am very happy with my amp even if I can't use the volume control.
thanks in advance.
thanks in advance.
