Help With Canal Phones! Aiwa VX-100!
post-145599
Thread Starter
Post #1 of 7
rockhard
I just got these phones, but i can't seem to get a good seal, this is my 1st time using canal phones, and i'm not sure what i'm doing wrong, when i think i get somewhat of a seal its just a matter of seconds before they fall out, can some1 help or give me some tips?!?!?!?!?
post-145629
Post #2 of 7
a1leyez0nm3
take one arm over your head and pull up on the top of your ear. with the other hand, put it tightly in your ear canal. let go with the arm over your head. this might work.
post-145630
Post #3 of 7
a1leyez0nm3
post-145641
Post #4 of 7
rockhard
just how far am i supposed to stick it in? I've tried jamming it in there pretty hard but am not sure when it is too much.
post-145672
Post #5 of 7
a1leyez0nm3
with my personal experiences with the ex70 i found that too far wasnt possible... just put it in until you feel that it will stay.
post-145688
Post #6 of 7
LTUCCI1924
Take your finger and wet them then just put then in. They only go so far. I think that wetting them will help a lot. I use mine every night on a radio show.
post-146040
Post #7 of 7
Superbaldguy
Since the VX100's are a "one size fits all" arrangement, the gasket may not go too far into the ear canal. After I got used to the way they sort of stay in place, I was reasonably happy.
Some users with smaller ear opening might actually be ablee to get them in, a bit. I think the EX70's can go deeper into the ear, and they do have a choice of gaskets, but do not sound nearly as good.
The VX100's are great buds, but, are not the answer to isolation. I'm almost ready to take the plunge and order a set of ER-4P's, if I can get them in Canada; I'm having difficulty making this work.
