dgshtav
- Mar 19, 2009
I finally got my K702 (Yes, I swapped the K701 for the K702 which is why it took so long).
Setup:
#1 Creative Muvo ---> K702
#2 Creative Muvo ---> Emotiva RSP-1 ---> K702
#3 Creative Muvo ---> Onkyo 805 ---> K702
Before I say anything else, let me say that:
•I have only heard a few tracks on these for 15/20 minutes max across all the 3 setups above which means even less time for each of the above setup
•As you can tell, I haven’t set these up correctly yet. The above combinations were merely to get the phones playing quick!
These appear to have a good open sound stage with a near natural sound though it is slightly inclined towards the highs. The bass is pretty lean for my tastes though and that makes it sound a bit dry as well. The separation is there but can be better (it’s probably the source, setup and no burn-in yet). As for the soundstage, honestly, I am confused. It’s deeper but at times I feel its more vertical than wider, I don’t know….I need more time.
I have a problem in this setup. The sound signal is bleeding into the main L/R loud speakers even with the HP jack on the Emotiva RSP-1 completely engaged. I have tried reseating the plug a few times but the same issue (and I know it’s not the plug, because I don’t have any such issues with my Onkyo 805). I will be working with Emotiva to get this resolved soon.
But even with the RSP-1 issue, the overall impression was same or better as that of the #1.
The first impression on the Onkyo was Uuuhghh! So I won’t say much (or maybe I just did!) at this point. Need more time here.
Overall, though no wows yet (and my expectations are very high), I really like what I am hearing so far even with the minimal time I got to spend with these on the less than ideal setup. I did get an opportunity to listen very briefly to some Ultrasones (sorry, I didn’t really register the model as I hated these so much that I didn’t even bother) and DT880s and I like the K702s much better.
Again, please take everything with a grain of salt. And to those who might be scouring for feedback on the K702, please ignore everything I have said in this post as these are mere first impressions from a mere few minutes of listening. Look elsewhere for experienced feedback.
Now that I have the K702, I am looking at some of the amps out there and I think I like what I am reading about the WA6. The Channel Islands VHP-2 looks like a good amp as well, but I don’t know how much the VHP-2 costs and neither have I come across much opinions on these. I also don't know if either would be available in a balanced config. Another beginner amp I am looking at is the X-Head from AV123 but I am a bit skeptical about it after the problems with rev-1 of those. I haven’t seen any reviews about the Rev 2 of the X-Head anywhere so any pointers on these would be appreciated.
Anyway, once the RSP-1 issue is resolved, I will be doing a HTPC ---> Cambridge Audio 840c ---> RSP-1 ---> K702 setup as Emotiva claims a high current output on the HP jack on RSP-1. Maybe I won't need an amp.
Thanks again everyone for your inputs.
- Dinesh
Setup:
- Dinesh
