Zro30
- Dec 18, 2013
Hi All,
OK - my eyeballs can no longer take thread surfing, so I will ask openly.
I'm looking to upgrade my set up, and would like some thoughts/recommendations. Generally, I think I'm looking for open back headphones with a tube amp. Below are the current considerations following much research. I listen mostly to House, Techno, and Tech House. Given this, I'm not a basshead (preferring balance), but do like it to be noticeably present. use will be in home only.
Headphone:
HiFiMan HE400
Ultrasone Pro 2900
Philips Fidelio X1
Other??
Amp:
Lyr
ALO PanAm
Little Dot MK IV (know this may not really work, but throwing it out there)
WA6 (maybe... bit pricey)
Other??
I may look at getting the bifrost with the lyr, or some other DAC perhaps recommended (bifrost is a bit expensive).
Thoughts on any of these, or alternate recommendations? Price range can be gathered based on current possibilities. Also, not opposed to closed back, just thinking open would be better. Do you think they'll disturb others in the house?
Hoping some direct opinions will provide direction...
Thanks in advance
Zack
Headphone:
HiFiMan HE400
Ultrasone Pro 2900
Philips Fidelio X1
Other??
Amp:
Lyr
ALO PanAm
Other??
Thanks in advance
Zack
