linglingjr
- Jul 26, 2011
So I bough some HD-600s second hand, they came with the stock cable but no 1/4th adaptor. They sound fine with the 3.6mm plug but instead of buying an adaptor I would rather just make a cable with a 1/4 plug. I don't really care if it "improves" the sound over the stock wire, as long as it sounds as good or better. I use them with a fiio e9/e7. So what is some good cheap wire to use? Also In the DIY cable gallery (which i asked this on but no help) I've seen different color and transparent connectors, does anyone know where these are sold? I can only find the normal black and red ones. Thanks.
