mfaughn
- Jan 28, 2009
I just received a second-hand EF1 modded with a kit from Hi-Flight. The essential aspect of this mod is really just replacing the stock opamp with a brown dog type adapter holding dual AD743. I notice a definite and audible distortion (crackily and fizzy on peaks). Each channel seems to be producing distortion in the other channel. To test/discover this I used an EQ to input only to one channel or the other. When I EQ out the left channel so that only the right channel is being fed a signal and then crank up the volume a bit it clips in the left channel. It also does not seem to produce distortion in the right channel (the one actually playing music). It does it the other way (left to right) also. So, when I run both channels I get clipping in both channels but in each channel it is caused by the other channel...make sense? More volume results in more distortion. The distortion manifests well below volume levels that would be considered unsafe listening volumes.
I thought at first that it was subsiding as the amp warmed up but now I'm not so sure. There is enough distortion to be REALLY noticeable and unpleasant.
I tried this while both feeding the amp a low signal and cranking its gain and also feeding it a high level signal and using the amps gain set low -- problem exists both ways.
The problem is also more noticeable/prevelant with DT150 than with HD650. A bit surprising as this is just 250ohms vs. 300ohms. Haven't tried it with anything else yet.
I've tried swapping tubes to no avail. I'm going to try putting the stock opamp back in and see how that goes. Any other ideas for diagnosis etc..? If I can't get this resolved the amp will be unusable as far as I am concerned.
Thanks,
Michael
Thanks,
Michael
