IEXPLODEBANANAS
- Jul 12, 2014
Hello guys, I want to buy a headphone (up to $300ish). Here are my criteria
- I want to here every little bit of detail
- I don't want my music to be over powered by bass (looking at you beats and sony)
- looks are not important
- durable, I have Senn HD 202 and when I fall asleep with them or sit on them their earcups just snap off without breaking
- comfortable, I'll have them on for 8 hours a day on average
- I'll need to be able to plug them in my MacBook or iPhone without an amp
- closed, most of my listening will be done in a library so leakage is not an option
- (preference, not a must) small enough to fit in a large flap-over case
- I mostly listen to: Oasis, Beatles and classical
- a decent amount of pressure on the head, since I mostly wear my headphones will I'm looking down some headphones (including my HD 202) slip.
Thanks for your help
