n_maher
Resistorous Conflagorous
- Nov 20, 2004
OH SNAP! Now that is good thinking. Only potential issue I can see with that is not having a big enough punch for the pot. But man, that would have saved some serious time in case prep. Thanks for the tip.
N
Originally Posted by Heady n_maher, I found out the hard way that you don't drill holes in tins, you use a hole puncher to make the holes. It works beautifully. |
N
