Hifihedgehog
- Oct 24, 2007
I am looking for information behind the math of crossfeed in order to better configure crossfeed filtering to the actual position of my headphone drivers. My thought process has been that crossfeed would very likely sound better, each spectrum (bass, midrange and treble) lining up and providing a more unison, dynamic sound if the delay, channel separation and shelf cutoff were optimized to the actual angling of my headphones. Here, this would mean that angling would be 150 to 180 degrees depending on the model in question. Part of my theory is, even at a wide angling situation as this, there is still not complete bass and midrange isolation between channels or sides like headphones produce. The real life scenario I am considering for this assumes music is commonly recorded with the microphone within three inches of the projection source (voice, instrument, etc.).
Now, as for your requested help, the methodology for me to figure out these numbers would involve a dummy head with two microphones mounted to the locations where the ears would be. As I have no access to a dummy head or its associated equipment to monitor the timing and leveling of the frequencies in such a configuration, I am wondering if there is a mathematic function I could work with to obtain some theoretical values and perhaps gauge what settings would be best for this. Thank you.
