fureshi
- Aug 19, 2003
i agree on some cables being too stiff and heavy. canare mini starquad is one of those cables that i think is too stiff for the light ksc35. i think mogami would be a good alternative since they tend to be more flexible than the starquad. while you're at it, solder in a 75ohm resistor between the two pads. i've noticed that it helps to tighten up the bass.
