TheGhostWhoWalks
- Jul 21, 2005
I've finally decided to make the switch to PC audio courtesy of an Esoteric K-01 (via USB asynchronous input) that will also do SACD playback, but I'm not entirely sure what all I need to make that switch. I'm planning on having a Custom PC built from EndPCNoise, but I'm not sure what features are necessary. Basically, I want to send the signal as cleanly as possible from the PC to the K-01 DAC, and I'm not sure how/if noise, jitter, sound cards, etc. would affect the chain. So, eg, is there any reason to invest in a better sound card? Or does the signal even pass the sound card on its way to the DAC? EndNoise offers a lot of "silencing" options, but I didn't know if stopping audible noise in the PC (like from fans and HDs) would have any affect on the audio.
I was also curious about running blu-ray audio through the K-01. I know it couldn't decode surround mixes, but it should be able to do stereo PCM, right? Would it be a simple matter of running the USB cable from the PC to the K-01 to get audio and then an HDMI from the PC to the monitor to get video? One of the things I'm looking forward to most (hopefully) is watching operas on blu-ray and using the K-01 for the audio.
