Sl300
- Sep 29, 2005
So i stumbled onto this site a few weeks back and i've been reading posts after posts about closed headphones just to get myeslf familar
I've always wanted a nice set of semi-portable headphones for home/library/bus purposes,
After reading the forums here for a few days i THINK i narrowed down my list to a select few, Keep in mind that this is my first purchase so i havent used any "hihg-end" set of headphones yet so i would like some opinions?
I will be using the headphones lets say 50% at home, 30% in the library, 20% walking around campus/busing or what not.
AH my budget goes up to 100, if needed 200 max
AKG 240M i heard is a great bang for the buck
Senn HD280 im hearing mixed reviews for these
AKG K271 a bit pricey would it be worth it? I read somewhere that these get really hot and are hard to keep on for long hours
Senn HD 437/457 Made to be portable, havent heard much reviews about this one
I listen to hiphop music 100% of the time, im a bit fan of old school/underground stuff is that makes a difference, Bass is not too much of an issue, i would like detailed sound, as long as hte bass is there and not too weak im happy. Treble must be crisp im not a big fan of hte buzzing noise at high volumes
I dont think i will be buying a amp for my headphones, Also keep in mind i'll have to lug these w/ me when i goto class everyday or if i go study in the library. I would be listening to these ranging from 10-40minute sessions, or up to 4 hours. I would prefer Closed Circumaural 'Phones, i dont want my sound leaking out when im in the library
btw im located in toronto/waterloo, canada i've been doing some searches but i havent found a store that may carry what i want, i think i will have to make it an online purchase
Any other suggestions other then the ones i posted above?
Thanks and advance!
Thanks and advance!
