Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
Yes, as people have mentioned elsewhere, the HD580 can only be considered 'luggable' phones, you won't be wearing these on the go. So the question is, how good is the 470's 'skip protection' with the antiskip off?
Can it withstand small jolts like you get when you're sitting in a bus or can it play properly only when put on a table?
Oh, and some of you have suggested higher/lower class systems. I'm wondering if I should just get a high-quality amp first and buy phones later. What can I get if I decide to throw all $275 into buying a (portable?) amp? What's the best portable amp out there? Or is the Porta Corda on top of all that and anything better would be tied to a wall socket / PSU?
OTOH, what if I throw all $275 into getting headphones? This probably sucks though becoz then I probably won't have any source to listen to it properly
Unless it's a Grado
If I buy a HQ amp I'll probably be better off because I can polish-a-turd and make my Aiwa HP-X225 sound great using digital EQ
I found that given the right signals compensating for the rough and unbalanced EQ response on my Aiwas they sound competitive with the Senn HD565 through the same source at my university library--but my pcdp is too weak to drive the eq'd tracks at a good volume and not distort
With a good amp I can hold off buying cans and polish-a-turd until I can afford super-duper phones
sig for this post: Who says you can't polish a turd?
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
