DanT
- May 1, 2002
At first glance from the service manual, I would guess that an under 5 minute job.
There is 7 clips and 7 screw holding it. So it's just a matter of snap in then screw in.
So unless, She done other damage to the frame it shouldn't cost much on labor. You can even do it yourself. However, you'll probably need the appropriate tools to jack the front of the car. You can use the old clips and screws if they are undamaged or buy new clips and screws.
Originally Posted by Konig /img/forum/go_quote.gif THATS IT!!!! THanks alot! how much does it cost roughly to get a mechanic to put on a new one for me in the states? |
